Guessing the shop didn't replace the slider pins on the front calipers... probably didn't clean and grease them either, and probably didn't shim them correctly or put "anti-squeal / chatter" material on the back of the pads.
There's an off-chance that you have a bad pad (I've seen chunks of metal in the pad compound on $100 pads - oops) OR a pebble stuck in the pad.
Can you inspect the front rotors VERY closely? Better yet, a good pic would help.
Let's figure this one out.
