240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Fri May 22, 2009 10:19 am
Say theoretically you had your fuel lines backwards. Order of fuel system is fuel pump, rail, regulator, return. Your gauge would show you having full fuel pressure if the regulator was installed before the rail but would cause a massive lean situation.
I know it sounds dumb, just throwing that out there.
Evan
EDIT; I have a spare S2 ecu Ill set you up with cheap. They are great to have around for troubleshooting, but my setup is so far from stock its not useful for me to keep anymore.
