tdenardoKAT26 »
https://forums.nicoclub.com/tdenardokat26-u182348.html
Sat Apr 09, 2011 7:23 pm
Your temp control (ac, heat, fan control, etc) in the car has a linkage that will guide the vent control to and from the heater core. That may have either broken or slipped off. If it is stuck at the heater core then all you will get is heat, regardless if it is recirculating or ac. For the ac to work efficiently the control can't be full heat. The heat will override the ac which is why you can make it less cold by putting the control inside the car closer to the heat. Its just mixing air. I would pull out your temp control unit inside the car and check the linkage. Check out the fsm for more specific locations. If you google search 240sx fsm it will come up with a link to this forum (idk it off the top of my head) and you can download the entire fsm on your computer. Hope this helps.
