Why a high flow cat?
ugaexploder
Car: 2007 Lakeshore Slate G35S
I was wondering why you would use a high flow cat if it's for "OFF-ROAD USE ONLY" when you can just replace the catalytic converter with a downpipe or something of that sorts.
I'm wondering because I live in atlanta, but my car is registered in columbus and i wanted to do something to the exhaust system.
You might mean a testpipe, not downpipe.
Adding a high-flow cat will keep you in compliance with emissions laws, while providing the same flow characteristics as a testpipe.
Honestly (and I'm certainly no environmentalist), I don't like the idea of testpipes. Cars were built with catcons for a reason, and eliminating them is just irresponsible.
bone_stock_240
Car: 1995 Infiniti Q45
AZhitman wrote:Honestly (and I'm certainly no environmentalist), I don't like the idea of testpipes. Cars were built with catcons for a reason, and eliminating them is just irresponsible.
+1
Cats make a huge difference when it comes to NOx and unburned hydrocarbon emissions. Both of those things are highly bad.
joe603
Car: 2014 Durango R/T
Its off-road only because it will no longer pass an emissions test. The aftermarket CATs will not be as effective as stock...but better than nothing.
ugaexploder
but wouldn't it be ideal to get the maximum amount of hp to use a test-pipe instead of a high flow cat? or are the gains in hp very minimal between the test-pipe and high flow cat?
thanks for the replies
joe603
The gains would not be a much as you think. Our cars were designed with a certain amount of exhaust restriction in mind. In fact, some FI systems will not perform as well with free-flowing exhaust (Stillen roots type blower).
I would look for HP in other areas...I think you'd need O2 sims to fool the computer, or get a tune.
We're not talking about a top fuel drag car...
ugaexploder
yeah that's understandable, thanks for all your knowledge joe. i remember reading stuff about the exhaust system on m3's and they said the stock exhaust was actually the best for the car. i might just go with stillen, i know they've been aroudn for a longtime. thanks again guys
I like the Stillen and NISMO exhausts on the sedan...
DJButton
Car: 2010 Nissan 240sx
The Nismo sounds and looks fantastic, I haven't seen a Stillen, but I'd imagine similar quality.
ugaexploder
i didn't even know there was a nismo exhaust out for the sedan. thanks hitman
