jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Tue Feb 05, 2013 4:55 pm
if you really want performance then drop the 20's thats rediculous go for for some 18's you will get better performance from lighter wheels in braking, handling and acceleration. depending on budget look at tsw, enkei, or volk. pretty easy to get something under 20 lbs if you go with a 18x8 or so. also 295 is very excessive on the rear if your not FI get some good tires in 265 or 275 widths the weight savings will be very noticeable. since its an 03 check all your bushings in the suspension, sub frame and rear diff, motor and trans mounts if excessively worn replace. sway bars are probably one of the most cost effective suspension mods you can do and provide one of the biggest jumps in performance outside of quality tires.
