ks13 wrote:well you should have measured, but you didnt is what your saying -
its the spring rate you should be worried about..after all..your trying to eleiminate valve float with after market springs..as far as the hight of the spring being different..did you take into thought that spring rate and hight are meshured under a preload contion?..like as when they are seated with there retainers...so relax man..dont look down on others for not slapping a mic on the spring..couse it really makes no difference when they are not installed and seated..now..if there was a difference when the spring was seated from original oem hight..then you would have an issue.
i run BC duels with Ti retainers.
