Okay, fixed my problem. Running on all six. Now to the next problem..
The motor will cut out once it's running hot, usually starting at WOT.
I've seen many threads who have the same symptoms as I do.
It cuts out, comes back, cuts out than will stall.
Then it doesn't want to fire up, so I let it sit for a minute.
It will drive, but will than go through the same process as before.. cuts out,comes back then stalls..
I switched my igniter, it was sitting on the valve cover.. so I thought it got too hot. But that did nothing.
I have a spare MAF, but I don't see why that would start to malfunction under high temps.
I have buddies who run the same plugs as I do, with same gap.. with no problems.
I wrapped my coil packs in electrical tape too. If I were to guess it would be my coils... but how do you guys go about testing this stuff when you're driving?
It revs fine in neutral, so I can't do it from outside the car..
sry for the long post
