sicwitit »
https://forums.nicoclub.com/sicwitit-u90139.html
Mon Jan 11, 2010 4:12 am
thanks you two for volunteering, as far as the reputation of who is manufacturing these pulleys.....oh if I could only go into detail what companies they represent. Remember I'm over here in JDM land, and have been learning the in's and out's of the aftermarket industry. I'm trying to determine if the crank pulley we already have made for the VQ35 for the 350Z and Altima will work. as far as its likely hood of destroying anything, the chances are minimal, but what I've done in the past is have someone ride around with you for a few minutes, swap the stock crank pulley with the aftermarket one, and take it out for a spin again. drive normally, if you notice any vibration at any certain RPM, then your engine needs that Harmonic ballancer (since they failed to make a sound engine in the first place) remove the aftermarket one, and never look back. normally 3cyl, straight 6, V6, and V12 engines don't need harmonic ballancers....NORMALLY, my straight 6 in my Lexus IS300 was very upset when I tried a lightweight crank pulley, on the flip side, we tested a 900Hp Supra, and it didnt have any problems? weird. the rest of the pulleys in the kit can and will still be utilized if it turns out the Pathy doesn't like the undampened crank pulley and should help with engine efficency, and increase voltage from a overdrive pulley for the Alt...I'm kind of thinking it won't only because I know they paid less attention to it then with the 350z VQ, . Only the tests will tell, I guess I should have who ever I end up sending them to test the output voltage before and after too.....I might have to throw in a volt gauge so you can read Volts and Amps at idol, and w/ load.
