ispypsi »
https://forums.nicoclub.com/ispypsi-u34943.html
Fri Dec 02, 2005 8:34 pm
t3/to4e 50 trim, Z mafs, 600cc's15 psi - unopened motor~23 mpg (25ish on road trips, but i just cant keep my foot out of it )
runs great, good for 12.6ish so far, only issue is that after driving it for a while, and getting into boost, it will fall off the map since its passing the maximum load value (TTP limit), and then in boost it gets really rich, but thats solved with turning the car off and on. otherwise its perfect.
i live about an hour away from scott, so after the holidays ill likely hook up with him and have it fine tuned and finally get some numbers.
btw, i have a '97, running the conversion harness (which is flawless) and a "31" S13 ecu. no CEL from all my obd-2 stuff i yanked out either.
