Who Scrapes with the Eibachs?
All things Altima Coupe.
hiroprotagonist2005
Car: Nissan Altima Coupe
they group buy made it only 180 bucks and i live in so cal so the shipping was free; cant beat it.
anyway, to everyone who drives with eibachs in socal; how often do you scrape?
I noticed that even now, with just the front lip spoiler, i scrape alittle more often if i dont go in/out of driveways alittle slower so how bad is it after the springs?
dl_yeunuoc
Car: altima coupe
After eibach installed. I have to park my car VERY carefully, and watch out for dips more often. But i still got lots scrapes under my front bumper. I think 19' rims would help a lot...
alphapig
Car: Nissan Altima Coupe S 2.5
dl_yeunuoc wrote: I think 19' rims would help a lot...
Lol wut?
You should always keep the diameter of the wheel/tire the same; meaning when you increase wheel size the profile of the tire should get smaller.
So all you will get on 19's is a bumpier ride...
I scrape my front a lot. It's unavoidable in La Jolla sometimes.
iiiskylll
Car: 2008 Altima Coupe 2.5S
I havn't scraped yet..but i've only had them installed less than a week. And i'm still rollin on stock 2.5 wheels. But i've been taking bumps and stuff a bit slower. There's not many potholes around here, but the 91fwy is hell; it has a buncha dips and bumps.
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
man my ride is so much more bumpier now.... in ny shiets insane sometimes.
i love the look when it's lowered and the turns are amazing with the RSB.
but... sometimes the bumps drive me crazy. its really harsh here in ny.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I edited your title...
Ive only scraped going too fast over speed bumps.. Other than that, the bottom of my car has never touched the ground.
Bmore-coupe
Car: 08 Altima Coupe 3.5
I never really scrape unless i do something stupid like fly over a speed bump. but that would scrape at stock height. and i did once leaving a parking lot that was at a 45 degree angle, but no avoiding that.
Voodoo Coupe
Car: 08 Altima Coupe 2.5
I've only scraped my car twice and they were both huge incline/decline type areas. other then that i drive my car like a bat out of hell I roll 245/45/18's with the pro kit drop and honestly unless you live somewhere where the roads completely suck or theres tons of driveways and parkinglots with entrences on hills you shouldnt have any problem at all. also I was just currious imdavit did you cut your bump stops when you did your spring install? I've driven a ton of lowered cars on tons of different spring setups the eibac setup on our cars isnt at all that bumpy compared to most.
Infantry1327
Car: 08' Nissan Altima Coupe SE
Ime rockin 245/35/20's ftmfw w/ eibachs and I have yet to scrape. But I am very careful parking and going over speed bumps and sharp inclines. You defenetly need to be more careful, but its worth it. The worst is parking because every curb is higher than your lip, and if you pull too far forward you are going to scrape. Narrow drive threws also suck, but if you are careful you shouldnt have any problems. On the road I have yet to bottom out or scrape and thats even cruising the 405 speeding in the fast line just after the grade headed towards L.A. If you have driven it, you know how messed up that freeway is there.
Jose3.5
Car: 2007 Nissan Altima SE 3.5
I scrape the lip and exhaust tips all the ****ing time and I've scraped the bottom of the car a few times.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
hiroprotagonist2005 wrote:they group buy made it only 180 bucks and i live in so cal so the shipping was free; cant beat it.
LOL..well obviously this is your first "dropped" car. I hardly scrape but scraping in a dropped car is inevitable. Just be cognizant when approaching dips and what not. Always go into it at an angle an go very slowly and you should be fine
maxentropy
Car: '08 Altima Coupe 3.5SE
dl_yeunuoc wrote:I think 19' rims would help a lot...
They do if you get a bigger tire.
My 19"s give me a few more mm of clearance.
mcheddadi
Car: R8
imdavit wrote:man my ride is so much more bumpier now.... in ny shiets insane sometimes.
deflate your tires from 33 to 28. that should help out a lot, if you want more smooth then deflate them to 25psi. you'll never feel bumps. ever.
imdavit
i got them stock 2.5 tires on, does that matter? cuz if it does im so doing what u are telling me to do. btw when i say bumpy i mean its pretty bumpy =[ i really hope this fixes it. thanks mc.
Voodoo Coupe wrote:also I was just currious imdavit did you cut your bump stops when you did your spring install? I've driven a ton of lowered cars on tons of different spring setups the eibac setup on our cars isnt at all that bumpy compared to most.
im not sure if they did that, but ima find out tomorrow when i let em install my front/back endlinks. what does that mean anyways? cut bump stops?
BigDankCloud
Car: 08 Altima Coupe 3.5SE
LongBeachCoupe wrote:I edited your title...
Speed bumps are the only time i ever scrape, and its just barely, and its only because i take the same speed bump all the time at the pub, and think i can go faster over it (meaning faster than 2 miles an hour) all the time.
For reference, this is a weird speed bump with the ground leading up to it sloping up, and the ground after it sloping down and away.
Oh and he was joking about deflating the tires. Do not do that.
mcheddadi
Car: R8
no serisouly, deflate them, it's pretty much the only EASY way to smooth the ride. tire wear will go up and mpg too. be warned , but since it's the stocker it shouldn't matter lol. try it out for yourself
if you want a smooter ride you can always remove the front and rear sway bar and swap some softer spring and dampers.
