spitz7985 »
https://forums.nicoclub.com/spitz7985-u2738.html
Fri Mar 05, 2004 1:14 pm
i'm not sure if this is going to work as good as the s14 setup, but I am going to give it a shot.
i am going to do one of two things.1) i'm going to cuz a hole in the intake pipe after the MAF, run a calculated ID hose to a crank case vent cone filter. the hose, i believe, has to be the same length as the main intake pipe from the filter to the hole. the hose will end up being rather small, not much bigger then 1/2" ID2) if the crank case vent filters are not large enough, I will cut two holes in the intake piping, one before and one after the MAF and connect the two with the hose.
not as efficient as the s14 setup. we'll see how it works.
