BigJuiceSr20 »
https://forums.nicoclub.com/bigjuicesr20-u7630.html
Wed Oct 18, 2006 8:38 pm
I've been running my automatic SR redtop S13 for over 3 years now. I heard the KA transmission can bolt right up to the bellhousing. That's a cheap alternative if you blow your transmission. Mine holds up pretty good though and I'm running 18psi with a GT2871.
Tip for automatics: I disable the circuit for the line pressure (resistor by driver strut tower) when I go over 5psi using a pressure switch and simple NC relay.This enables a quicker shifting when I'm boosting.
