:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue Dec 28, 2004 6:44 am
No...voltage curves are very different, and even the SAFC cannot compensate for it.
Your best bet is to use a stock S13 MAF and SAFC.
But with this...MAKE SURE you do something about ignition timing!!!!!!!!!!
Knock the base timing back a couple degrees, at least...otherwise you'll still blow something up.
- Brian
