Royal pain barely begins to describe it.. I also installed a Pioneer Nav Sys 910 GPS/DVD unit in dual din style in it... I still owe some pics..which I will get them here hopefully soon
I've installed a bit of alarms/remote starters over the years. Make sure you situate your alarm brain first..even before you mount the siren..then guide the wires to where you need them to go, towards doorlocks, parking lights, horns etc etc. I look at it this way, you can always trim excess wire rather than come in short. When you mount the siren, try not to guide the siren wiren to it...i.e.. don't make the siren wire visible in plain sight. First rule of stealing an armed car is to pop the hood and cut the siren wire. Don't run the alarm brain power wires directly to the battery. Another thief tactic is to cut these as well, thus defeating the alarm brain. Run them to the constant 12V wire found at the ignition key unit. Mount the brain in a hideaway location. I usually mount them behind dashboards, space in the radio pockets, behind glove boxes etc. Secure the brain as well..use velcro, tie-wraps, duct tape etc. I don't fly for the "stick your alarm brain high up in the dash" nonsense. I'm not a fan of suspended objects, especially in dash areas where they can falldown, short circuit, or worse, tangle into steering columns, brake pedals etc. Also, use a multimeter to test and verify wires before connecting anything.. I use a pen style SOAR multimeter.. Do not use a test light..especially in a car with airbags..regardless of who argues otherwise.. Also solder your wires if you can..especially ignition wires. Or, you can use 3M scotchlok quick splice, T-taps, and Bullet connectors to get the job done. I personally use 3M Bullet connectors on ignition/starter wires and tape them off with black duct tape or Electrician's tape. I use T-taps to tap into doorlock wires and door triggers..and quick splices for parking light wires etc. Use split loom tubing to run wires so they are neatly organized and look like factory wiring. If you have never crimped before, learn to do so. There is a right way and a wrong way. I have learnt with experience, advice, and practice. A lot of folks advice against t-taps, and quick splices. I use 3M parts and in 8+ years never had to redo an alarm/starter install yet..including many of my own. Choose the path you would like to take. Check out some sites and read up if you are not experience. These are good sources of info and knowledge.
http://www.the12volt.comhttp://www.inst ... =forum;f=3 and
http://forum.sounddomain.com/f...ne=10
Lastly, I installed an Autopage RS-850 2-way in the J30. The current model is RS-855.
http://www.autopageusa.com. This alarm has everything you can imagine to do a security/remote start combo on any car. Built in relays, temp sensor, pager sensor, shock sensor with glass sensor. Two-way lcd communications and these are just a few to mention..the range is not shabby either..started my car from my mailbox, six blocks away! It also has numerous programmable options such as factory arm/disarm, turbo timer, stater disable/anti-grind, dual pulse priority locks so you can keep you factory remote style feature of unlocking the drivers side first and then unlocking the remaining doors if needed. etc
Good luck and post here with any questions if you need help.
Modified by metaverse3 at 6:22 AM 11/15/2004
