OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Sat May 16, 2009 11:03 am
I have a hybrid rear. Q45 housing (r200V) input of the case was cut off (no speed sensor). Z32 Turbo input pinion, R200 S13 welded open end internals, 3.69 R200V Q45 ring gear with 6 bolt axles,
But yeah what you are trying to do is possible, but you need to swap the 240 ringgear and input pinion (I think they are different teeth count) I may be wrong they may both be the same now that I think about it. Just pull the guts and count the teeth on the pinion. If they are the same stuff the VLSD into the R200 and use the proper shims.
