Who's 3rd gear sucks?
Cyberkreig
Car: 1993 Nissan 240SX SR
i skimmed the thread, just put me down for a slight 2 > 3 Grind
SilviaS14KA24DE
Car: Doriftu
yeah, I have that 3rd gear once in a while. although it doesn't happen a lot when pushing hard or drifting (yeah right, like I'LL be in third drifting, pfft!)
spitz7985
Car: HICAS S13
SilviaS14KA24DE wrote:Double clutching is a downshift technique as crzy said.
you can match revs without double clutching, just rev it up when you have the clutch in while you're moving the shifter. you get two things done at once then, instead of clutching, shifting to neutral, reving the motor, clutching, shifting into gear. seems pretty damn pointless to me. maybe double clutching was made up for people who can't walk and chew gum at the same time and then it was made famous by my personal favorite :rolleyes The Fast and the Furious.
i rev match in everyday driving. actually, when i'm a passenger and the driver does not rev match and just lets the clutch out slowly making the engine catch up to the driveshaft from idle rpm, it gets irritating because of the jerk forward.
i cannot see any instance when double clutching is a good method to shift. someone please enlighten me.
SilviaS14KA24DE wrote:oh, heel-toe rocks! I've got it down and i can take corners like craaazay!
i started doing this when i first learned stick in order to match revs while braking. i didn't even know it was a racing technique until quite some time after i had been doing it on the street for months! hah.
TachyonS14
My 1st-2nd shifts in the mornings when it's cold would grind if I shifted too fast. Also, my 2nd-3rd shifts wouldn't grind, but it was really notchy for some reason. I fixed both of those problems by switching to Penzoil Synchromesh gear oil, that stuff owns.
LOL pills. Everytime I see your icon I can't help but sing that song.
whiterps13
Car: white LE hatch
WeldingHank wrote:heel-toe, gotta love it!
no offense, but wth are you talking about? heel toe has absolutely nothing to do with an upshift. a heel-toe is a braking/downshifting technique.
burnin240sx
[ZERO-S] wrote:No, you can rev-match upshifts as well. I did it all the time...
--Too bad I was just going through the process in my head and yes, it would be faster to wait that half-second in neutral as the ka doesn't drop revs all that fast.
I stand corrected.
Thanks for correcting yourself you saved me the trouble.
For other readers doble clutching from 2nd to 3rd allows the input shaft to slow down faster so I can shift with out grinding my 3rd gear. Defiantly not faster if your syncro's are not fed up.
spitz7985
Car: HICAS S13
spitz7985 wrote:you can match revs without double clutching, just rev it up when you have the clutch in while you're moving the shifter. you get two things done at once then, instead of clutching, shifting to neutral, reving the motor, clutching, shifting into gear. seems pretty damn pointless to me. maybe double clutching was made up for people who can't walk and chew gum at the same time and then it was made famous by my personal favorite :rolleyes The Fast and the Furious.
burnin240sx-Do you actually clutch twice, or do you just pause in neutral?
