Who runs 11's?
Blast down the 1320? Love the 1/8 mile action? Here's your forum.
ANVIL
Car: RB25DET S13.5
goal for my car next year is to get into 11's. Would like to get 11.4-11.5 ultimately. just wondering you guys who do run 11's what kind of HP / tq do you guys put out? Im in the market for a new turbo and want to be sure I can be in the hp range to potentially hit 11's. I ran 13.2@106 / 13.3@108 (with 2.0/2.1 60 ft) this season on pretty much a stock rb25det, tuned 12psi for 266rwhp. i will be upgrading tires and most likely LSD (probably after turbo setup is complete) to try to better my 60ft.
would 400whp be enough to get me there? this is in an s13 hatch btw.any help and advice would be appreciated
ANVIL
Car: RB25DET S13.5
wow, no one here runs 11's???
240z4u
Car: '95 Nissan 240SX
Ill let you know how close I get tonight.
kzoosho
Car: Turboed 1997 Nissan Maxima SE
Im running 12's
efeezie
400whp is definatly enough for 11's. I did it a few years ago with some heavy 17" sportmax's and DR's with 380whp
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
266hp is all it made at 12psi?
Wat is your 1/8th mile times?
Im running a rb25 on Stock turbo @ 15PSI and I pull 1.6 60fts and 7.80-7.90's in the 1/8th mile which should be mid to high 12's, But I dont have a 1/4 mile track around here to see.
Sounds like your motor is lacking something, I would think at 12PSI you should be making well over 280hp, Also 400 Hp should get that car in the mid to Low 11's easy.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
scott thats why you need to come to FL, moroso motorsports park is almost all set and the track looks vicious!
ANVIL
Car: RB25DET S13.5
rb25drag wrote:266hp is all it made at 12psi?
i dont remember what my 1/8 mile times were, ill have to check the slips again if i can find them. im not too dissapointed with the hp... ive seen guys here with worse numbers. i mean, mine is an S1, stock 250hp @ the flywheel. also, thats 90 octane gas, which is "premium" up here and w/o LSD
also, picked up a new set of wheels, 17x8 in the rear. looking to get a set of DR for, what do you guys recommend?? and where can i buy them? seems like those mickey thompson's are bad *** for low 60 fts. i was looking on a few websites but couldnt find any with prices. also saw that there were like 3 different MT DR.
ANVIL
Car: RB25DET S13.5
efeezie wrote:400whp is definatly enough for 11's. I did it a few years ago with some heavy 17" sportmax's and DR's with 380whp
what car/engine? do you remember your time & 60ft?
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
i run 11s but i think you already knew that...
11.67 @117 w/1.6 60'
i run N/A z32 wheels with 255/55 BFG Comp T/A drag radials not that new crappy design
this was done on a stock rb25 block with a gt3076r and about 18-20 psi on a base power fc map
i cant wait to get this new motor done and see what she will do in the spring
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I'm making 368 whp on a Dyno Dynamics...
Latest pass:60' - 1.931/8 - 7.944 @ 931/4 - 12.10 @ 122
I'm going back on Sat. to launch for real and get my 11 sec. slip. The mph is there, but the ET is miserable. I had to make a 250 mile road trip the day after so I didn't launch it hard (had no backup axles).
Vid --> http://www.streetelite.net/vids/12_1_pass.mpg
For tires, check http://www.summitracing.com They'll be right on par w/ the lowest prices you'll find retail wise unless you know someone. On an 8", I'd go 255 width, but your best bet is to find a 15" wheel and get a bias ply wrinkle wall slick that you use only for the track. Reduce your chances of snapping an axle and it'll hook better.
bxs13
s13 w/sr on e.t street [email protected] 60ft11.5 @ 123mph
[email protected] 60ft10.6 @ 134mph slipping
nissandrftr88
Car: 34 240'S, 3 rx7's, 06 & 07 gsxr 1000
RB25,stock everything except greddy intake,80 shot,300zx ecu untuned.
[/QUOTE]
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
That was from back in the day. He was probably still stock block KA / s13 at the time. He finished that car with a 700+whp KA-T. What he is building now is much more evil
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
Me, I ran the 11.7 last fall and run 7.5 1/8ths all day long. Haven't been on the dyno with the tomie cams and 25psi but it will be 380-400whp. I ran the 11.7@116 with 345whp and MT ET streets. All you need is a gt3076 or a borg warner S258, even a holset HX35 for low 11's with the right tune. I have a GT2871 and a 2.0L and I easily run 11's, you should have no problem with the RB25!
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
kentuckyslider wrote:Me, I ran the 11.7 last fall and run 7.5 1/8ths all day long. Haven't been on the dyno with the tomie cams and 25psi but it will be 380-400whp. I ran the 11.7@116 with 345whp and MT ET streets. All you need is a gt3076 or a borg warner S258, even a holset HX35 for low 11's with the right tune. I have a GT2871 and a 2.0L and I easily run 11's, you should have no problem with the RB25!
good call man i ran 11.67@117 on a power fc base map and a gt3076r on 20psi...completely stock block...this coming year its gonna be fully built bottom cams and a good tune more boost and a wet 125 all the way down the track...
Return to “Nissan Drag Racing Forum”
