They'll leave a slight frosted look on things if you put a heavy coat on them as well, so don't use em on glass or black stuff.Are coated items “breathable”?
The breathability of a coated item is dependent on how heavy the Base Coat is applied.
The lighter the Base Coat, the more breathable the item will be. If a continuous, heavy film
is applied, the surface will not be breathable.
Do that this weekend and post the results. I want to do the same thing.krash wrote:Definitely spraying down my wheels with this stuff
You don't wash it. Why would you?Looneybomber wrote:So you spray this on your shirt and spill BBQ all over it. Clean! But, once you go to wash your shirt, if no water penetrates it, how do you wash it?
I did. I was also thinking about what the pH could be. Maybe its so strong it repels vegetable and/or motor oil too ? Id like to see that demonstration tho. They need to make super hydrophilic towels!Dattebayo wrote:Okay, so if we know it repels water-based stuff, how well does it do with oils, fats and lipids? These are the things that make our clothes dirty, not water. Did anyone think about that?
They talk about that in the FAQ as well.Dattebayo wrote:Okay, so if we know it repels water-based stuff, how well does it do with oils, fats and lipids? These are the things that make our clothes dirty, not water. Did anyone think about that?
NeverWet is less effective at repelling motor oils and oil based liquids
