who knows gear and final drive ratios for 2007 auto and MT?
ampsucker
i think i found the MT, info.
from car and driver:
DRIVETRAINTransmission: 6-speed manualFinal-drive ratio: 3.69:1, limited slip
Gear: Ratio: Mph/1000 rpm Max test speed I 3.79 5.5 42 mph (7600 rpm) II 2.32 9.0 68 mph (7600 rpm) III 1.62 12.9 98 mph (7600 rpm) IV 1.27 16.4 125 mph (7600 rpm) V 1.00 20.8 158 mph (7590 rpm) VI 0.79 26.4 158 mph (6000 rpm)
i interpret that to mean the MT has a true overdrive gear and the differential ring and pinion is 3.69:1, so true final drive on the highest gear in the 6 speed is 3.69*.79 or 2.92:1.
can anybody confirm this or put up the numbers for the auto gear box? i'm interested most in the fifth gear ratio and the differntial ring and pinion to see if they are different for the auto setup. i suspect they are.
thanks!
ampsucker
bump... ;-) anybody with an 07 auto have this info?
amp
