Who is using ARP HEAD STUDS???
New2SR20
Car: 89 240SX
For those of you who are using them...how did u tighten them...what torque???? and what procedure??...
Gramentz
Car: s14
Lube the threads up with the lube that came in the box. Thread each of them in finger tight. Then, tighten according to FSM procedures. There shoulda been a piece of paper, I thikn it was pink, that came in the arp head stud box that has torque specs..do you have a FSM?
corey240
Car: 1993 Nissan 240SX Base Drift Machine
i lubed up both sets of threads, used and allen wrench to get them things all the way finger tightend down (after the head is on not befor), then i put the nuts on at 25 lbs, 50, then like 70? search and youl get your numbers if the paper didnt come with yours for some reason
jr_ss
Car: 95' S14
You have to install them after the head is sitting on the block. I went 25, 50, 75ft lbs. You have to loosen them inbetween each torque set. Search to get the specifics.
