OKAY. I've been getting a lot of questions from people all over the different boards, so I'll just anticipate some of your questions and post the answers here:
It IS in fact the camera angle that makes it look like you're gonna hit the distrib with a pipe to the turbo inlet. Here's a better pic:
and here's what Jim said about it:
Quote »It is definately the camera's angle that is making it look like that. A picture is worth a thousand words so have a look at the attached. Yes you can use a straight pipe if you wanted to it will clear, though a 45deg pipe might look a little nicer and point the filter towards the spot behind the headlight a bit better. Either way will work.[/quote]Also, the manifold is designed to have the turbo top mounted OR bottom mounted with no modifications, so if youre still not convinced for some reason (I dont know why you wouldnt be...), you could bottom mount your turbo as well.
Jim says:
Quote »We made the manifold so that the turbo can point down or if you want to move the resivoir point it up, it's your choice. We notice that some guys point down some point up so we made it so that you can do both.[/quote]And lastly, concerning size, I'll just quote Jim right here:
Quote »The material is 0.127 thick which if I remember correctly is equivelant to a sechedule 80 pipe though I would have to go back and look at the chart to be sure. Most manifolds that use crappy material are maybe .070 to .080 which is why they have problems with cracking etc.[/quote]I hope this answers everyone's questions. If there's anything else, please dont hesitate to get back to me, I'll figure out anything you need.
And remember, IM me (foosternit) or email me (
[email protected]) if you want in on this deal. I sent in my deposit today: this is definetly a go.
EDIT: By the way, the deposit is $200 CANADIAN, which is about $150 something american... just so ya know.
