Who is good at math? (tire size question)
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Gr8dave37
Car: 2008 Blue Onyx Versa S
Ok...so right now I have 225/40r18's on my car and it is lowered with the tanabe springs. The ride has been a little rough since I got it and figured maybe if I added a little more rubber, I could smooth the ride out a bit.
So what I'm reading is that in the same width, I can get 225's in a 45, 50, 55, or 60...with the car lowered...anyone know what the max fit would be?
blindsnyper
Car: 2007 versa
225/45-18 tires are .9 inches taller than 225/40-18225/50-18 -- 1.8225/55-18 -- 2.6
the largest tires ive seen on a V or 215/50-17, 1 inch taller than stock. your current tire size is .6 inch taller than stock....
i just confused myself
feloniousmonk
Bad idea.
First, you're killing your ride with thin sidewalls as it is. Second, you're going to be adding more overall diameter, weight, and rolling resistance, not to mention overloading already overloaded brakes.
OriginalWheelman
Car: '15 Ford Focus Electric
Return to “Versa Technical Discussions”
