Who in Central Florida can change my headgasket?
OmarM
Car: 1989 Nissan 240sx HB
Anybody know any reputable shops or people for this job, and also pricing on this task? I am planning on replacing headgasket with a stock replacement and adding ARP head studs.
Should I get a complete gasket kit for the head that includes valve stem seals, valve cover gaskets etc. Or just replace the head. Im not sure which is cylinder 1 on the car, I assume the closest to the cam gears, but i may be wrong, that is where it is leaking coolant and probably why my compression is down a little. I think my last compression test was atleast 150 on all cylinders with a variance of 5-8psi.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
OmarM wrote:Anybody know any reputable shops or people for this job, and also pricing on this task? I am planning on replacing headgasket with a stock replacement and adding ARP head studs.
You sure its not the water pump itself that isn't leaking? Its right under the intake cam gear.
jt15833
Car: 95' 240SX
yea that compression/variance seems too good to have a busted hg. get shop to leakdown test cylinder 1 to check, if doesn't leak out hg its good then get them to pressure test coolant system and check for the leak. cake!
MikeDombeck
Car: 1995 Nissan 240sx SE S15 SR20DET
sean from this website would know someone who can help you.... also enjuku is a shop around here...
OmarM
This leak is on the exhaust side, and the compression test was when I bought the motor so those numbers could be skewed now. Sorry I should of said that in the beginnning my fault. But I will do a compression test and leakdown test this week.
