WHo here with a 1991-94 Q45 has had problems with the TCS?
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Who here has had problems with the TCS on 91-94 Q45s in which the TCS and the SLIP lights would come on and what did you have to do to fix it.Thanks,MattJacksonville, FL
qship96
Car: 1996 Infiniti Q45
usually it is the relays under the battery that go bad,my only problem in 150,000 miles with the system stemmed from a faulty throttle position sensor,which also screws up idle speed and shift points.
mattd1979
I know that I also pulled a code 13 from the TCM which refers to the secondary throttle sensor is open. Aparently because the TCS is in failsafe mode.
JoshIsSciFi
Car: 92 Q45
the only time i had a similiar problem is when my alternator died, but then agian, it had EVERY light flashing light a damned christmas tree... but those two where the ones to flash on, as well as the brake light, the most.
