mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Wed Dec 08, 2004 5:21 am
The fault code I am getting is code 18. According to the FSM it says that if after I perform the test accordingly for code 18 and it passes then go to procedure 19. I did procedure 19 which involves testing the TCS actuator in which it failed the test. So according to the FSM, the TCS actuator is bad. The previous owner had the relays replaced by Infiniti and still had the problem with the TCS/SLIP lights coming on.
I am mainly trying to find out if anybody else had the same problem as me and to see if replacing their TCS actuator solved the problem.
