Who here is using a T2x (T25 or T28)?
Chezedik
Car: 1991 Nissan 240sx
I was wondering if anyone here is running a T2x, and if so, what is your setup. What kind of numbers do you have (HP, TQ, MPG)? How does it feel in the seat of the pants. What are your impressions? Would you do it again, or would you rather use a larger unit.
iknowyoulike
t25/370cc/wideband/~27 mpg <---didn't really change after boost unless i stomped it constantly.
well it's better than no turbo that's for sure...as for numbers it was fore sure 200 whp it did pull you to your seats if that's what your asking..i'd do it again..it's a really easy setup to put together..but if your looking for a quicker than stock but don't have to much to spend then this type of a setup is for you... all in all i loved my setup.
Chezedik
How did you tune it, or did you just drop in the injectors? What happened to your setup, did you lose it?
Chezedik
Bump for anyone else?
iknowyoulike
street tuned with the wideband and S-afc..yeah the injectors where a direct drop in affair.. as far as your question about did i lose it no i didn't i just sold it...in it's place shall be a sr20 setup wid a street tuned t28.
Chezedik
Sounds good, I may have a T3-60 compressor side with 50K on it, no chips. I believe that is what they call the Big-28, but I can't back that up.
