carkook »
https://forums.nicoclub.com/carkook-u93381.html
Fri Mar 06, 2009 12:05 pm
Easiest route(not the best) maybe two hours.
1)Set motor to TDC, remember what your dist. rotor points too (either 1 or 4)
2)Drain coolant, removing the radiotor will give you much more room, not necessary
3)Remove all belts, pulleys, tensioners off front of motor
3)Remove Crank pulley
4)Remove valve cover
5)Remove timing chain cover
6)Swap timing chain and guides
Now reassemble. I did this myself, so I dont want people telling me you wont have enough room or that it wont work. No need to remove the oil pan. JUST DO IT stop being a little girl.
