who has the most mileage on KA-T
Syntax360
Car: 1986 Nissan 300ZX Turbo
I'm wanting to know who had the most miles on their KA before turboing it (w/o full blown rebuild, etc). I have 103,000 on my KA, but I swear it's in great shape. A guy at the shop i go to says i'd be crazy even think about turboing it, but those guys are the kind of people who don't believe anything is fast unless it has a chevy or ford badge. I want to run 5psi, w/ intercooler and slightly upgrade fuel system/HKS SAFC. If tuned properly, wouldn't it work? If I am just dreaming, I guess i'll buy a low mileage KA from a junkyard and turbo that, but I'd rather take what I have and run with it. Well, that was lengthy (sorry). Also, how many miles have u guys racked up under ur belts on the KA-T? I searched, but no one has really addressed my pre-turbo KA mileage question. Thanks guys!
eastcoastchaos
Car: 95 240sx
good call, i've got close to the same mileage and don't see any reason why i can't go turbo at low boost.
Syntax360
hey, we should start a club....we'll call it "Four Cylinder Pipe Bombs" ;-)
ka24de_510
you could get a KA with 50k on it for probably around $400-$500 if you look. it's a small price to pay to be more confident about your machine, and you'll have a backup.
Syntax360
ya, but i'm trying to avoid swapping engines. i'm just trying to find out the highest mileage someone has had before turboing the KA....just to make sure there's someone out there who's "been there and done that" w/o any problems :-)
Jeff240sx
Car: Car! Chicks!
A guy in CT turbo'd his 140k mile engine. It was also a budget ($1000) turbo setup.His compressor busted, oil shards gunked up the oil filter, starved cylinder #4, and snapped his rod.Anyway. I did mine at 83k miles. -Jeff
Syntax360
thanks Jeff240sx! Any success stories out there?
Jeff240sx
Car: Car! Chicks!
Sure. TY from FA has had his running 10+psi (up to 18psi) for 40k miles. Dennis from UH has run for 6 months at 15psi. These are both stock KA24DE motors pushing 350rwhp for Dennis and 359rwhp for TY.Mine only blew due to the wastegate line comming off, and the CT guys only blew due to his turbo dying.-Jeff
JDM_180SX
my ka has 126k is it even worth trying to boost? or should i do a minor rebuild to it first?
Syntax360
JDM_180SX wrote:my ka has 126k is it even worth trying to boost? or should i do a minor rebuild to it first?
that's precisely why I started this thread. I want to know if i'm crazy to turbo my 103k KA.
C-Kwik
Do a compression check and a leakdown. This should give you a very good idea about the condition of your motor. If these tests show good results, there is a good chance you won't have very many problems by adding a turbo to it.
Grandpa
I'd say look for a low mileage KA. That's what I did. I just swapped in a 39K mileage KA that I got for $675. I mean, common, even if you do the turbo yourself, it's still going to cost you around $2000 to do it decently. Why not put it off a little bit longer and throw in that low mileage engine? But hey, that's just me...
-john
Turbo_Nismo_EC
Car: My truck...of course
It really all depends on a lot of variables...the condition of your current engine(which you swear is good), how much boost you plan to run(which is minimal), how you will drive the car with the turbo installed(are you going to be on full boost all the time, or only some of the time?), and how well you tune the system you get. It seems to me that you should be ok as long as everything is in good working order. I don't see why it would do much damamge to turbo the engine you have as long as these are in reason. I've got a buddy with a N/A 300zx and he installed a 150 shot Nitrous Express system on his car with over 150,000 miles on it. But he takes excellent care of his car and he hasn't had any troubles with it for the year or so he has had the nitrous on it. To me, adding 50 hp to your car with 103,000 miles shouldn't be much different. Just do some tests(like a compression test) and a good tune-up before you start and I would think you will be fine. There is no difference in an engine that has over 100,000 miles, that someone took good care of(i.e. changing the oil regularly, keeping it tuned-up)...and a 50,000 mile motor that someone neglected(i.e.- 10,000+ miles between oil changes). I have seen low-mileage enignes that have been jacked, even though they don't have that many miles on them.
For example..I went through some of the same things you are going through now when deciding to turbo my SOHC H-Body p/u. I thought that there was no way I could turbo my 140,000+ mile engine so I bought a used engine to rebuild from a salvage yard. I thought I had a great deal. I engine had only 42,000 miles on it according to them so I bought it. I think the original owner NEVER changed the oil. The cam journal was damaged, the bearings were worn, and it had about 2" of sludge in the pan. Now I sold my original engine to one of the guys who worked at the machine shop that built my current engine for me. He then took it down to put a slight rebuild to it and called me to ask me and asked if I had changed engines before. He could not believe that it had 140,000+ miles on it. He said there was little to no wear on the bearings, no major scratches on the cylinder walls, and there was no carbon build-up in the combustion chamber. This just goes to show that since I religiously took care of my engine there was nothing wrong with it...even at 140,000+ miles.
If you have confidence in how well you take care of your engine and you firmly believe that it is in perfect condition, I would say run with it. Besides, even by some chance you do blow it up in a year or so, you can always get one from a salvage yard. Don't let my story scare you, I'm sure that what happend to me will probably not happen to you.
Hope this helped,
Jason
d240t2
TY's car was low mileage when it started...and it has always been at the 280+rwhp. I think he runs 320 daily...and the higher numbers were on race gas.
My car has been turbo since last December...so it has been turbo for a good bit over a year...and has 20+K miles on it in that time (drives from GA to TX, then Fort Worth to Houston and back repeatedly, etc.)
TY probably has the longest running, time-wise, KA+T without any major issues.
Dennis
Jeff240sx
Car: Car! Chicks!
And I'd venture to say the most miles put on it, also...-Jeff
mulletmrt
Car: Videography and Film
I got a question. What about a KA24E? I've got a spare one I'm going to turbo. I plan on only boosting to 10psi. Should I buy just new stock pistons and rings and gasket or do I need built up forged aluminum ones. I know the forged with last longer, but with the stock ones last while at this boost level?
Syntax360
does he really need forged internals for 10psi? that seems like over kill. As long as ur tuning is good and there's no detonation, I doubt u'll need any of that.
214kka-et240sx
Car: nissan s13 silvia
i have a 89 ka-et with 214,456k on it a still pulling faster than a 350z at 10pis
crzycav86
Car: 93 Nissan 240SX KAT
I'm in the middle of turboing my 145k dohc ka.. This is after I put on new oem timing chain parts and oil pump
K240
Car: 1993 240sx
Im supprised slos13 has not replied to this thread yet. He has a 200,000+mile ka24det, that he has been running 10psi daily...I think its a stock engine too... Im rebuilding a 100,000 mile KA for turbo too.
nissanfanatic
Car: 1992 Nissan 240sx SE
135k. 1400 of it on boost(5-6psi)
Toahk
Car: 97 ....
Damn this thread is old, anyways 272k miles on my ka-t. I win
IanS13
126K turbo 5psi now upgrading to 370cc afc and 8psi, go for it.
Craving4Boost
Car: 91 240sx fastback
damn amazing lol
Craving4Boost
^^ talking to toahk
XcreatureX
Car: 96 240sx SE
i got 107k i just checked compresion the other day and i am right at 180-183 spec is 179 so i dont see why i would have one bit of truoble turboing mine....i am probably still going to rebuild the engine cause i want power but i dont think i would need to do it if i didnt want to
drifts14x
Car: Cars, Motorcycles, Drifting
195k on my KA, my Compression came out perfect across the board, mileage is not the problem, just check your compression, I'm going turbo with 6.7PSI, why can't you?
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
I will post for slo13 un till he gets off his @$$ he had 213k on his ka till he swaped a newwer one in last i knew of it was @ like 16psi so so long as there in good shape thay will last
SloS13
K240 wrote: Im supprised slos13 has not replied to this thread yet. He has a 200,000+mile ka24det
Sorry, taking a bit of a 'car break' right now to save up some money. visiting this board tempts me to spend money if you know what i mean
Bought car with ~199k miles
Boosted at about ~203k running 5psi, shortly after that started running 7,8,9, then ran 10psi for about 4-5k miles or so.
Got some 480cc injectors then ran 12psi for about 1-2k miles
That got boring and started to run 15-16psi until I finally swapped the motor due to a bad front-main seal. Swapped in a 93k S14 KA (set at ~12psi).
car is currently having problems, but thats another thread another day.
hannibal
Car: Red Line to Glenmont
This is the same guy that brought back Structure's thread.Quit searching for old *** posts about KA-T mileage. We all know you have 214k miles on your KA-E and it can beat a stock Z33.And SloS13's got you beat by 60k miles. You got a lot of driving to do...
Slo!!Long time, no see...
