who has sr t25 on there ca18det?
silentkrnsouljah
ok nico people, i have few questions and seems like i cant find on the forumesso here it is1. where do you hook up ur waste gate since sr20 t25 doenst have little nipple thing not like stock ca t25 turbo doese.2. it has 2 broken studs stuck in the exhaust side of turbo and i couldnt take it out so i just put it with brand new turbo xs manifold and dump pipe do you think there gonna be a exhaust leak? 3. im pusing 10pound of boost and turbo has hks actuator but seems like car is slower then my stock ca t25. when i had stock turbo i was pusing 12psipeople say i can turn it up the boost to 14psi but its my daily driver and i dont want to hurt my motor or either turbo. my current set up is FMIC, turbo elbow, down pipe, apexi gt spec, wallboro 255 pump, 300zx fuel filter, stock injectors, stock MAF, SAFC
i know its alots of questions but im a noob so i need you guys to give me some tips.i would really appreciate ur help
RS12Turbo
Here's what I use on my t25g for a boost source......works like a champ, and easy to install...........http://www.atpturbo.com/Mercha...e=BCS
Bwana
Car: Denali
1: Hook it up via a T off any vac/boost source on the intake manifold, OR drill you're compressor housing, tap it with an 1/8" pipe tap and put a fitting in there.
2: It will probably leak.
3: I would suspect tuning. The SR t25 flows far better than the CA t25 at that pressure, so tuning is likely the culprit.
silentkrnsouljah
thank you very much for ur infos guys
