RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Tue Aug 10, 2010 11:21 am
I got rotors pads and bearings coming in day or 2, I understand the rotors separate from the hub via some 14 MM bolts. Any tricks to getting the rotor off the hub? I have a feeling they will be tight, all that heat and such. Anyone who has replaced the rotors and know any short cuts I appreciate any tips you can give me. I have done rotors but no 2 part ones like this truck has. I just want it to go as easy as possible. I know on the drums on back there are bolt holes that a long bolt can be threaded in to pop off the drums. Any tips or hints are welcomed and appreciated. Do not want to mess up the old hubs removing the disks.
