ObsessiveDad »
https://forums.nicoclub.com/obsessivedad-u306865.html
Mon Jun 02, 2025 4:34 am
I've read many posts about the "normal" vibration and growl in 2nd gen rogues at low RPM, and now wondering if I have it...or if it's something else. So for those that haven't found a culprit, how long have you driven with it? And has anyone got to the root of it?
2015 SL, 177K KM, first CVT fluid change was just shy of 100K, I've done two since at around 30K intervals. Oil changed regularly at 10K, never noticed metal in either fluid with a magnet drag through the catch container.
It's my wifes car so I rarely drive it, but she recently complained about shuddering while braking, turns out lower BJ's were gone on both sides, so I replaced the LCA's.
But something else doesn't "feel" right. I haven't driven it in a long time, but here's what stands out now that didn't before.
- Starting/cranking sounds "sharp" if that makes sense, like a higher pitched sound than before, and i'm pretty sure it's louder, but it starts fine every time, no hesitation.
- There's a general vibration at idle. Roof box rattles.
- When taking off from a dead stop, there is lurching at low speed from 20-30km/hr in the 1000-1500rpm range, IF you accelerate slowly. Over that speed or RPM it goes away, and not noticeable if you accelerate quickly, or even at a normal rate. You have to go intentionally slow off the line to make it happen, and it doesn't happen if there is any initial momemtum at all.
- When coasting slow (again 20-30km/hr range), if I tap the gas lightly, not even enough to rev the engine, there is a click. Sounds like it's coming from the TC, could just be the backlash I guess, but I've never noticed it before.
- The overall growl is definitely associated with engine load, as it goes away as soon as you let off the gas. It's not wheel bearing noise.
- I've had to replace some exhaust sections over the last year, so initially I thought there was a hole somewhere, but the more I drove the less it seemed like exhaust noise. It doesn't increase the same with heavy load that a normal exhaust break/hole noise would. And there's a noticable "rotational" quality to it at lower speeds.
No engine codes, and I drove around with CVTz50 running, and all CVT values are in spec, with no codes. I did run the idle air relearn, which seemed to smooth out the idle a little but that may just be in my head.
Also ran electrical system load tests, alternator was ok, but battery needs to be replaced.
I'm paranoid about the CVT due to all the horror stories, so am I looking for a problem here? Or does this sound like an issue (or multiple) that someone has diagnosed before?
