FTRS14.5 »
https://forums.nicoclub.com/ftrs14-5-u3490.html
Mon Feb 03, 2003 10:02 am
Don't mean to rip on you, but you ARE asking a lot of questions that can be simply found using the Search tool. Just to answer a few.....It's better to get a clip, wiring should be professionally done, make sure you double check everything BEFORE you put the motor in, and if you are getting it put in by Unstable, then you shouldn't even have to worry about things like that. Just have them take care of it....also try to get a motor from them as they WILL charge you more if you don't.
