who has an E-T and who has a DE-T?
w1ngzer0
Car: Pfft. i don't own a box
I need to compair the 2 with the same boost amount like 8-10psi.
Structure240sx
you are going to find the same results. plus the only way to really compare would be the EXACT same setup on each. this would be very hard since the exhuast ports are spaced differently making exhuast flow different and uncontrolable in the experiment
w1ngzer0
Structure240sx wrote:you are going to find the same results. plus the only way to really compare would be the EXACT same setup on each. this would be very hard since the exhuast ports are spaced differently making exhuast flow different and uncontrolable in the experiment
true, i thought i would give it a go anyway. Thanks
