Who has added HID kits to the EX?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
lybrian1
Car: 2008 EX35
hi i will be installing 2 HID kits tomorrow: Low beams and fogs.im getting 8000k for fogs and 6000k for low beams it would be great to hear what combinations any else has . oh and white LEDs for parking lights.
i havent hooked them up yet because i want to hear details about your install. (where to mount the ballasts and whether or not you hooked up a rely wire. i would even like to hear about any problems or troubles you had. we all know how poorly designed the EX is
AWGD8
Car: 2008 EX35 AWD JOURNEY
zerothread?id=392969
I bought a relay harness that plugs directly to the battery.
Make sure you buy a nice relay harness with Tyco relay switch.
After 3 months of driving with aftermarket HID during winter time, I had a
terrible no light or one side light only isssue. The first thing I checked was
the relay switch and that was the culprit. During winter time, these
terminal on the relay switch got corroded (green stuff) and this causes the
hid not to fire. I replaced it with the new BOSCH (now Tyco) relay switch
and the hid fires consistently. I also wrapped the relay switch with
electrical tape to prevent moisture seeping in to cause corrosion.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
