Who has AC in their CA?
GotBoost4Yall
Car: Cars-DSMs/Nissans
Florida is too damn hot for No A/C, the motor came with a compressor ,and i have my original lines from the car. What can I Do?
Does anyone have a/c lines around from a clip??
240 Trainee
I have a ca compressor as well, I am assuming that you can just bolt the KA lines onto the KA compressor, and charge it up, and be good to go.
creophus
Car: 240SX SE & 200SX
GotBoost4Yall wrote:Florida is too damn hot for No A/C...
I couldn't agree more! I have A/C in my SR. And I know you asked about CA, but I couldn't resist! :D
float_6969
you'll use the KA compressor, bolt it to the CA bracket, and then take both compressors to Nissan and have them swap the pullies.
biosehnsucht
Float, I've been wondering about that since hearing they bolt up but pullies don't align. is the only reason to take it to nissan that you need funky tools?
GoofyATX240
Bio my friend James can probably make you some lines for the CA compressor. Hes making mine hehe, and some other things.
biosehnsucht
I'd rather not have to recharge tho! I got good R12 here!
GoofyATX240
Alright hehe. Ill be recharged for free only cause I know the guys though.
rico05
Car: 1992 RMS13 w/ CA18DET
So only the Nissan dealer can swap the pullies over?
XtremeHKS
float_6969 wrote:you'll use the KA compressor, bolt it to the CA bracket, and then take both compressors to Nissan and have them swap the pullies.
That's weird I just used CA stuff and My A/C works :-D
mulletmrt
Car: Videography and Film
I couldn't agree more, florida is hot. I'm on the beach coast and it still sucks monkey balls when a breeze is not present. I have a s12, I haven't been able to get a look at the DET compressor butr will mine from my CA18ET interchange?
Mike
NeedCAforS13
Car: CA swapped S13 coupe
a/c is next on my to-do list... this heat is kicking my a$$ recently. it was 95 degrees today, and I was sweating my balls off:(
If I have a CA a/c compressor, is there any fittings that are the same (as a USDM car) or does anyone have lines (cut the fittings off and send them to me? TMS?;)) I'm gonna have an a/c shop custom make me some lines, so I'm not too worried about that, I just need the actual fittings on the compressor... suggestions anyone? I know the SOHC compressor one fits, etc etc... but I'd like to figure out how to make this CA one work, seeing as I had a DOHC car to begin with.
Sean
f s t caz
Car: VG30ET D21 Extended Cab Pickup
i should. just have to get the rubber grommets that go around the lines into the firewall and then charge the system. but then again, i don't think my setup counts
float_6969
Ok, here is what I've done/what I have to do. I had a SOHC KA. I swaped in the CA. I'm using the KA A/C pump. AFAIK Nissan is the only one that has the right tool to do this, but I could be wrong as I haven't looked around much and I've got a hookup in the local Nissas service department, so my stuff always gets taken there if I need help. It is possible (and has been done) to have the CA pump lines brazed onto your KA lines and they not have to swap pullies. The reason I'm going to do mine the way I am, is because it was just charged with R12 3 years ago and has a new compressor on it.
rico05
Will a KA24DE compressor work? I have half the lines from my CA pump. I will prob just take in all my lines and get some custom ones made up if the DE compressor dosen't fit.
What kind of shop can make these lines?
float_6969
A KA compressor will bolt up to the bracket. you'll have to swap pullies or have the lines brazed on.
slw240sx
Car: 1990 Ca18det 240sx Hatch
whoops i gutted all my AC stuff under the dash ,90+ degree weather with tons of humidity its like breathing water it sucks. but thats why i have window and non leather seats.
rico05
Ok cool. I wasn't sure if the DE compressor would work as well.
NeedCAforS13
float_6969 wrote:A KA compressor will bolt up to the bracket. you'll have to swap pullies or have the lines brazed on.
single cam... yes.
twin cam... no way in hell.:)
Sean
rico05
See, that is what I thought. Thanks for the misinformation float ;)
PalmerWMD
Car: 2004 350Z
Thats an interesting subject you brought up.
I am toying with that idea for my SR as well.The condenser is still on the car "all" I'd need was a compressors and lines n stuff.
But compressor=$$ also a aftermarket sunroof migfht do the trick.But then I wonder how much is my body's stiffness commprosed of I do that since the car came w/o sunroof and what seam to be a load bearing element runs over my roof.
Fred...:)
float_6969
Doh! I missed the DE part, sorry about that.
Fred, I'd just get some A/C hooked up. Leave that coupe stiff like mine. I need to check, but I may have a spare DE compressor. I don't know how it works for the SR, you might want to check on it.
PalmerWMD
Car: 2004 350Z
Keep me posted..
Fred..:)
s13conv
Car: '86 GT-S Coupe
So if you have a CA in a DE car you need which compressor?
Nismo1182
Car: Z06
SOHC or the original CA compressor. OR you can swap the pulley from the CA compressor onto the SOHC KA compressor.
The SOHC KA pulley doesnt not line up with the rest to put a belt on.
float_6969
:withstup EXACTLY what he said. You can hook up your AC either using the CA pully and haveing lines brazed on, or by using a SOHC compressor and having the pully swapped from the CA compressor. I'm not sure if a SOHC compressor will bolt up to a DOHC lines though....
