Who does ECU reprogramming?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I was thinking about getting a JWT equivalent ECU, and hearing how they are nearly impossible to get, and the Stillen ones are 800 (WAY out of my range), I wanted to know if anyone here does it.... I assume I would send in my ECU, they would reprogram it and then send it back... How much would something like that cost???
Id also like to know what it does..... I heard from Q45tech that it leans out the mixture, and moves the rev limiter to 7300...... Is that all??
My Q is a TCS, non active, California....
acmeblues
Car: Bible, Music,I35
Hi Elwesso, a co. called technosquare in torrance california does reprogramming. They list 1994 Q45 at $495.00. There no. is 310-787-0874,web site is http://www.technosquareinc.com. Their site tells what their ECU reprogram does. Ask for Danny Lee. Hope this helps
PalmerWMD
Car: 2004 350Z
Good link acme!
Wes, alse you might try to email NICO member aaacomp, he used to do this for us, might be wortha try.
Fred...:)
QShip
I got mine from aaacomp for alot less than $450 and it does work. I put the ecu in 1qckser's Q and he was very impressed. He said he wanted to get one.
As a matter of fact, I'll be sending my TCU to aaacomp to have him reprogram that as well.
elwesso
2007 BMW M Coupe
Hmmm... I emailed aaacomp and he never responded.... I guess Ill try again.....
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Personal preference, I'd only use JWT. Yes, Virginia, it takes for-e-ver to get it back. (My 91 SE-R w/ 100 shot module took 5 *months*, but that was because I told them "take your time, I'm in no rush")
Best way to do that is to pick up a ecu & tcu from a junkyard, install them in your car & send them yours. That way when you do get yours back it's an unexpected Christmas present.
By & large, a JWT ecu advances the timing to take advantage of 93 octance *exclusively*, bumps the rev limiter, corrects any anomalies in the a/f mixture, (perhaps a little leaner where it can be and/or adds fuel where necessary,) and moves any speed limiter to a speed beyond where the car would ever reach anyway.
Edit: On this application, engages VVL sooner.
QShip
My ecu has the JWT code.
elwesso
2007 BMW M Coupe
Where did you get yours done??? Did JWT do it.....?
QShip
Aaacomp did it. It took him less than a week to get it back to me.
Call the number on his website and you might get a quicker response. I talked to him about three weeks ago.
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
We removed the ecu from Qships car and placed it in mine and I can honestly say it made a really nice difference, the power seems like it really comes on after 4000 rpms, after my suspension is complete I will be purchasing my ECU from him.:)
Q45tech
JWT also changes the tip in throttle retard; When you WOT from standing still the ecu doesn't remove as much advance and the amount it does is added back sooner........makes it feel a little peppier.
With any ecu reprogramming you must make sure the coolant temp NEVER exceeds 194.9F as read and translated by ecu as the lack of knock protection [less knock retard] can be harmful to engine.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
On this Aaacomp ecu, do they replace the daughter board like on the JWT? That's the way my 91 SE-R was done, I guess it's the same with the other Nissan ECU's?
At least with JWT, reprogramming is quick, once it's been done the first time.
QShip
I don't how he does it. You'll have to call him and ask.
elwesso
2007 BMW M Coupe
If you dont mind me asking, how much did you pay???
QShip
$250
