Yep, that the problem I am having, I need someone to fabricate a wiring harness or piggyback ECU to send the MR20 the signals from the MR20 ECU. I dont know if the Versa ECU is a "plug and play" with the Versa's wiring harness, cause if it is, then it would be a matter of swapping the ECU, Engine and transmission. But something tells me thats easier said than done.Red Devil wrote:The only difference between the 2 seems to be the stroke. The MR18 has a 81.1mm stroke as opposed to the 20's 90.1mm.
Swaps aren't simple in and outs. The Versa ECU will not work with the MR20. It has fuel maps, timing, e.t.c. designed for the smaller engine. If you also swap the transmission you'll have issues there as well. It's not as simple as you think.
There are going to be issues with ANY swap. It's never a simple in and out.mightyversa wrote:Ok man, now we are getting somewhere. Can you list the issues that you know about. It will help me out big time.
Ok, gotcha. Yeah I know its not a simple in and out, but I am after doing them about say 10 times, and its easier everytime. I find new ways to do things faster and already know what to expect. But I think I might have some luck because I am using "basically" the same engine, same year and similar vehicles for the swap. I definitely need an ECU, I know that, but since the engines are almost mirror images of themselves, would the mounts be in the same spots? Along with the pulleys, accessories? I think so, I have access to a shop when I want to do this thing, and I will be taking the bonnet off and pretty much working like a ***** to get the thing out, but I want to get all the help I can get regarding wiring issues. I think the wiring is the major issue, if I have to go ahead and switch mounts I will, but for now, I think ECU upgrading is top priority.Red Devil wrote:
Motor: It most likely WILL NOT just drop in. The Versa and Sentra are based on 2 different platforms. This will change motor mounts, the transmission, e.t.c.
ECU: You'll need a reflash, MR20DE ECU or aftermarket ECU. The fuel maps, timing, e.t.c. will be completely different from the MR18DE.
Fuel: It may or may not be an issue. I don't think there will be any large difference in fuel needs between the 2.
It's not as simple as you'd think. What makes a swap easy is a few different things. Take the usual KA-->SR swap most 240 owners go with. The motor WILL drop in easily. Why? It's the JDM engine the 240 was designed with. We got stuck with the KA because of emission regs. Was it easy and simple to do? No. It IS easier than, say, taking an RB, LS or 2JZ and trying to put it into the 240.
Not likely. Is there a possibility?. Maybe, but still not likely. The Versa is based on the B platform. The Sentra is based on the C platform. The possibility that the MR20 from a different platform will swap out without major mods into another chassis, even though they are the same engine family, are not likely.mightyversa wrote:
The engine? Yes. Engine bay? Noreyes1212 wrote:I was like..holy crap that's almost identical.
