30+ years of changing my own oil. Mobil 1 Syn + Nissan filter = I think there is an article that telcoman did....maybe in the FAQsBut, remove the bottom cover!!!! I tried to do it thru the access hole the first time and made a BIG mess!!!!!riceqx2 wrote:Do you remove the entire bottom engine cover when you do?Has anyone been sucessfull trying to use the access holes without making a mess?As often as I like to change the oil, I suspect that removing the bottom cover each time will result in stripped bolts or stripped clips that the bolts screw into. The access holes look too small to remove the oil drain plug or filter without making a splash...
Get yourself a set of sockets. The 14 10mm bolts to remove the fiberboard shroud underneath my G take less than 2 minutes to remove. I use a cordless drill with a socket adapter for my 10mm 3/8" drive socket. The oil drain plug needs a 14mm 1/2 drive socket. Sears has decent socket sets on sale for around $100.00 Buy yourself a 4 ton hydraulic jack and jack stands. My G will be getting its 30th oil change next week.I also do a tire rotation every other oil change.riceqx2 wrote:Do you remove the entire bottom engine cover when you do?Has anyone been sucessfull trying to use the access holes without making a mess?As often as I like to change the oil, I suspect that removing the bottom cover each time will result in stripped bolts or stripped clips that the bolts screw into. The access holes look too small to remove the oil drain plug or filter without making a splash...
I think I have you beat in the driveway oil changes (mine is gravel) I take it in, but now I will be poor for a couple of years. Has anyone simply hinged the area over the filter?Poyzinous wrote:Oh yeah? Well I've done about 5,000 oil changes!!! Well I haven't done a driveway oilchange in over 5 years
Just take it all down the first time to see how it goes.riceqx2 wrote:Do you remove the entire bottom engine cover when you do?Has anyone been sucessfull trying to use the access holes without making a mess?As often as I like to change the oil, I suspect that removing the bottom cover each time will result in stripped bolts or stripped clips that the bolts screw into. The access holes look too small to remove the oil drain plug or filter without making a splash...
