who can tell me what i can take off for emissions on a s14
Rekless KA
Car: 96 240sx
i have read write up's on taking vacuum lines off and everything u dont need to have thats all for emissions, but i can only find s13 info, no s14, does anybody know of what i can take off? please let me know asap!
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
get the FSM, and pull everything you don't need. all u need is maf, iat, o2, injectors, tps, iac stuff
egr, evap, map/baro, etc can go
Ligouri Rd
Car: '96 Nissan 240SX
Do you have emissions testing up in Verona? If so then in my experience there is not much that you can take off without screwing yourself for testing. I capped off and removed my egr but left the solenoid valve, tricked the egr temperature sensor with a resistor, and used a o2 simulator in place of the secondary o2 sensor. I am throwing no codes but the ecu will not complete its readiness checks...so I fail emissions.
Unless my car magically completes it readiness checks (I have already been through the factory proceedure to no avail) the car is getting registered in unincorporated Wisconsin.
Matt: Did you remove all the items you have listed above, and if so how are you passing emissions?
Rekless KA
Car: 96 240sx
no we do not have emissions here. ok so i know what i can take off but now i just need to find out what goes to what. i dont any of that. any help here???
matt4pl
grab an fsm, it has vacuum diagrams and all.
on the motor i have a MAP sensor, TPS, IAT, wideband 02, coolant temp, and the cam angle sensor in the dizzy. im running a MS though, and emissions, well i havent figured that one out yet. no maf cause its got open stacks, header with 2nd cat gutted, far from legal
Ligouri Rd
This may help:http://www.sharebigfile.com/fi....htmlI printed it, and saved it as a pdf before Fiznat's pics got lostAll credits go to Fiznat for writing it up.
..fixed file location
Modified by Ligouri Rd at 8:21 AM 3/15/2007
Modified by Ligouri Rd at 2:01 PM 3/15/2007
