elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Dec 07, 2004 11:15 am
So if I understand correctly, the Z uses 4 piston fronts and 2 piston rears...
and then, i can use the 32mm rotors with these... Correct??
All I want is 32mm rotors, and the 4 piston calipers would be nice as well.. the Q EATS rotors like you woudnt believe, about 8000 miles and they already need trued (may be less, I dont know when it was done last)...
28mm rotors on a Q45 isnt a good idea... however, i will be selling my Q45 brakes and rotors...
