TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Fri Feb 13, 2004 5:13 pm
Oh LadyInRed, I've had a vibration with my 240 for over 6 months. I've done about everything possible. My vibration really comes on at 2krpms. I think I've narrowed my search down to a fuel problem. But just yesterday, I tested my fuel pressure and It was fine... The search goes on.
A good way to check for is to see if the vibration occurs while idling. Because if the car vibrates when its not moving, how could it be the tires or alignment :-p ?
Here's what I've done to combat my problem and yet no success: I've gotten new spark plugs, plug wires, O2 sensor, cap and rotor, air filter, fuel filter, cleaned the throttle plate (which was very dirty btw) all new motor mounts (left, right, and transmission), I also ran Seafoam through the gas tank, crank case, and brake booster line, checked timming
