Did you freeze the bushing in your freezer and heat up the subframe a bit with a torch? I haven't done them yet, but that's what I was planning on doing, ha ha. Also, did you cut out the sleeve already?jtk240 wrote:I am trying to install the whiteline sub frame bushings. I am guessing a press is needed to do these.If you have done these and can help out with the process I would greatly appreciate the help.
ES bushings are so much easier but after you remove the cups you have no choice but the whiteline or megans.
