whiteline springs
tex240
i am thinking of the agx and s techs but i am considering the white lines. does any one have them and what do you think of them and does anyone know the spring rate on them. that is what i am worried about the most thanx
tex240
i did search nobody knows about them or if they handle better then the s techs
Exar-Kun
Car: 2005 350Z
I prefer the S-techs from a personal standpoint, but the drop is very similar and don(pdm-racing) has a great reputation for dealing good products.
so..that doesnt help much, but if had both sets sitting in front of me, I'd grab the teins.-chet
Meantime
One important note - the Whiteline set has a linear front and progressive rear setup.
S-techs are progressive in both front and rear.
tex240
thanks i will probably go with the s techs
240Stilo
Just because they are progressive all around does not mean that they are better for the car's handling. Whiteline explains in their website that they made progressive springrate for the rear and linear spring rates for the front because it will help the handling. The linear spring rate for the front is 157lb/in. The progressive spring rate for the rear is 107-178lb/in. I've heard lots of times that during a track event, instructors have told the driver to soften up the back because it was stiffer than the front. Whiteline probably nows this which is why the linear rate will initially keep the car front stiffer than the rear; that is until the rear reaches it's 178lbs/in max.
