Whiteline Rear Camber Bushings????
Kenny_D
Anyone have them? They are suppose to replace the stock RUCA bushings to give up to an extra 1.5 degrees of camber adjustment. I only need 1.5* to get where I want the camber to be. The reason is Autocross. You can't switch to all-metal sphericals from stock rubber bushings, but you can replace with Urethane, thus the Whitelines.
Kenny
Eddie
Car: 1995 240sx se
I have them.
Kenny_D
Do you like them? Do they work as advertised?
Eddie
Car: 1995 240sx se
They do work as advertized. With one kit the rear upper control arm and traction arm bushing is replace with the offset hole positioned to induce + camber(4 bushings, 2 bushing per side). Then the camber can be corrected closer to factory specs. Super easy to install the hard part is getting the old bushings out. I havn't had any problems with them. They surve there purpose well.
