White tip Plugs?
Xxplosive959
Car: 91 240SX SE
Ok guys, i mostly been bitchen about my idle how is crap even after i took out the aiv and cleaned the maf and etc... But i took out my plugs and the tips were white. i changed back in like sept And i put about 8 to 9000 miles on it. What do white plugs mean and do they any indication of an idle problem which is killing me???? thanks in advance
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Is the white present only on the tip...or on the entire bottom of the spark plug? Can you post some pictures?
Xxplosive959
Car: 91 240SX SE
its only on the tip. The closet threads are little brown. I'll see if maybe i can get some pics
Checkered-Member
Xxplosive959 wrote:its only on the tip. The closet threads are little brown. I'll see if maybe i can get some pics
Sorry, I wasn’t specific enough, is the white on the electrode (the part that generates the spark)? Or the firing end (the part the spark goes to)?
A pictures would help
TogueDrifter
Car: 91 B13 SER
I think it means Lean...
RPS13_Shift
I had white sparkplug tips when one of my injectors fried, and I just replaced the injector and everything was back to normal operation.
Checkered-Member
TogueDrifter wrote:I think it means Lean...
Not always, it's sometimes hard to tell on the KA, a little bit of white-gray is normal, if the whole plug is blistered white, many things can cause that: incorrect heat range of plugs, a problem with the cooling system, too much timing, intake manifold leak, and lean air fuel mixture.
