It has not over heated, none of the fluids are mixing and its good on fluid levels.
It got new fuel injectors a few months ago, got a oil change a while back.
So I went to drive it one day and it did not over heat but there was white steam with a semi burning smell coming out of the engine, most the smoke was coming up from the fire wall near the oil dipstick area. THen white steam smoke started to come out of the tail pipes, I let the car sit for a bit and it never over heated it just continued to steam/smoke
I parked the car and left it alone for a few months and took it out today (it was a bit chilly) took the car out for a drive she drove fine once we got up and going, drove for about 10 min got out and noticed white smoke coming from the engine, opened the hood and the white smoke was back coming from the same area and then the smoke came out of the tail pipe...
The car is always garaged and other then a few little oil puddles there is nothing on the ground to show there is a major leak and all fluids are at the same level.
anyone have any idea before i drag it to a mechanic...
hopefully the pic will open its on my facebook took a pic of the steam/smoke
