White Smoke
BoroBoroS13
Car: S13, RS13, and S14
My car smokes a lot while warming up (It looks like theres a small fire or something coming from my exhaust). The smoke is white which would make me think its coolent but its not. The coolent level in both the radiator and overflow have not gone down at all over two weeks. Its not fuel because it doesnt smell at all. Its not oil cause the smoke isnt blue and the oil level hasnt gone down at all either. Its driving me nuts cause I cant figure it out... I do have a gutted cat but it had the same problem before but not this bad. Any ideas/advice would be great, thx.
float_6969
does it quit eventually?
boost_boy
Turbo is possibly crapping!
Dee
GoofyATX240
Get ready for a funeral for the turbo heh.
BoroBoroS13
Great... I guess its time to get a T28. At least now I have an excuse :D
rico05
Car: 1992 RMS13 w/ CA18DET
I saw white somke the other morning. Seems that when I put my car up on jacks to get the DP on, the fact that I have no vent tube on my exhaust valve cover (read open hole:() some oil spilled on the DP :O Oops. When I went to start it, after it warmed up, it burned it all off. Need to find some way to fix that soon...
float_6969
Yea, you still didn't answer my question....
BoroBoroS13
Yes it does stop after I start driving or its all warmed up :)
pulsar gtr
Car: NISSAN VEHICLES
Well, float6969 asked the question, my opinion is if your car only does it on warm up, your valve seals are toasted, it doesnt take much of oil "few drops" to make it to the combustion chamber and you will see a cloud of smoke, which it will not effect the oil level almost at all, as it only needs few drops.
PULSAR GTR
Rafi
BoroBoroS13
I would like to get some more options on this. I plan to take my car down to my friends shop and see what they have to say about it though. Thanks
boost_boy
Could be either dealing with a failing headgasket or crappy turbo! Oil seals smoke only momentarily and doesn't smoke that heavily in the morning or after the car has been sitting for a while. I think it's more of a coolant issue when the words "White smoke" is mentioned.
Dee
BoroBoroS13
Yea, it smokes a lot (Like a small fire) when its been sitting for a while. For example, if I go for a drive, wait 1-2 hours, then go for another drive it wont smoke at all. Only when I havent drivin the car for quite a few hours and let it warm up. And the smoke isnt blue/black at all, its straight white. There is also a little bit of water that comes out of the exhaust when it smokes like this.
boost_boy
Quote »There is also a little bit of water that comes out of the exhaust when it smokes like this.[/quote] Did your old motor blow a headgasket really bad? If so, it does take a while to burn off old coolant in the exhaust. And did you change the exhaust from your old set-up? If not, then your headgasket is failing "Point Blank". There's only so many things that can cause this and they have been cased in this thread. You need to do some testing and figure which one of the issues that myself, pulsar_gtr and float have covered and see which one(s) pertain to your situation. Otherwise, you're beating a dead horse and this thread will linger into nowhere for you.
Dee
rico05
Mine has started doing this now. Weird thing is, if I start the car and let it warm up, it takes a few minutes to smoke, then if I rev it a little, the smoke stops. It only seems to smoke when I leave it sit overnght. I left it set all day while I was at work (10 hours) went out to go home that night and no smoke. Plus, this never happened till I got my downpipe.
BoroBoroS13
My old motor didnt have a blown head gasket and the only thing left from the exhaust system on the KA is a gutted cat.
I have a feeling its going to be either the head gasket or the turbo.
Thanks guys
boost_boy
Keep in mind the fact that your turbos are not brand new! Once the cartridge shatters, it will let some oil and water into the back housing, which will in turn cause these smoking conditions. If you want the smoke to stop, disconnect and block-off your water lines to your turbocharger.
Dee
rico05
What about my situation? How it stops after I give it a quick rev. Mine is blueish so it must be oil. O and mine came with a nice and unabused (no bent fins or chips on the compressor impeller) SR T25.
boost_boy
Quote »What about my situation? How it stops after I give it a quick rev. Mine is blueish so it must be oil. O and mine came with a nice and unabused (no bent fins or chips on the compressor impeller) SR T25.[/quote] Rico, your turbo is obviously starting to give you grief as well. And just because it's an SR unit, doesn't mean that it's previous owner didn't give it hell.
Dee
GoofyATX240
^ Like he said heh. Use it as a paper weight.
rico05
Sweet. Gives me a reason to justify a new T28!!! WOOT!
First I blow my KA to get a CA now I blow a T2 small for a T28BB.
Now only if my damn loan refund check would get here....
