White smoke...
beezkneez
Car: one slow 240sx
Well, I went to a tmobile store today, and as I was leaving, when I started the car, it started to whistle, then POP, and sputter sputter sputter..
I added transmission fluid cause I needed it, and thinking the engine blew a gasket, I added two FULL quarts of 10w30..
THEN, I hear where the whistle was coming from, which was a vaccuum leak.. I re connected the hose, and zip tied it..
I start the car, it starts fine and dandy, but when Im driving down the main road, white smoke POURS behind me, I should upload the video of it, people get scared of it lol.
My question is, is the car burning oil because I added too much? Did I ruin something?
When I drain some of the oil will it subsied..? Sorry for the newbness but thanks for your time in advanced
KoukiTony
Car: 1998 Nissan 240sx
It's not burning oil. Oil burns in a bluish color, and if i recall correctly coolant burns in a whitish color, which is why it's probaby your head gasket.
fabrisuzu
Car: 1992 240 coupe w/sr
i agree, my head gasket and turbo seals blew (bad luck i guess) and i was burnning both oil and coolant. The oil was blueish (like 2 stroke smoke) and the coolant was white (they were not usually burning at the same time which confuses me even more). Good luck
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
My guess is you recently overheated or messed with the cooling system?
beezkneez
Car: one slow 240sx
lol did no one read where I said I added two extra quarts of oil..
I came to the conclusion oil doesnt compress, therefore its getting into my exhaust and burning there.
I drained out about 2.5 quarts and the smoke is gone..
But also I added 1.5 quarts to the auto transmission cause Im foolish. Would that be the culprit for first gear bein laggy?
fabrisuzu
no i read what you said, but burning oil is a very distinct blueish color. Thats pretty weird that your losin oil and white smoke is comming out. If you dont have a problem doing it, i'd say park on a piece of cardboard (if you car is not too low lol), and check in the morning for dripps. Have you checked your coolant level?
alms24sebring
'04 Nissan Sentra SER SpecV
I mean as long as the dipstick reads good I wouldnt worry. low coolant + missfire + white smoke = head gasket. I think it might just be 2 seperate problems. Leaking/burning oil along w a blown gasket.. Good luck
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Do you under stand how an engine lubricates and cools? I read you were low on oil, and you added, but where is it going? Did you check for intermix, did you check compression.
alms24sebring
^ my point exactly. If the oil looks like a melted chocolate frosty, you've got a problem.
Speaking of melted frosty. I had a late model RX8 come in for just an oil change. It had just turned 40k miles, fill with oil, start, check level.. chocolate shake. Stupid rotary's and their unreliability
