es.biggs »
https://forums.nicoclub.com/es-biggs-u154499.html
Tue Aug 17, 2010 4:52 am
I would go with a set, that way you get your intake and exhaust manifold gaskets, balance tube o-rings, intake valve cover gaskets, the half moon seals, IACV gasket, cam and front crank seal, and probably some more I'm forgetting. These are all things you should definitely replace with a HG job.
I bought a Beck/Arnley set. I'm comfortable with Beck/Arnley; I have bought a lot of products from them and never been disappointed. They are an OEM supplier for lots of parts for several auto manufacturers. They make quality products, and it is a lot cheaper than the Nissan OEM gasket set. My machine shop also prefers Beck/Arnley. Some people would suggest using that set for the smaller, less important gaskets, then using Nissan OEM head gaskets. That would be a good idea if you are concerned about their quality - you build your engine the way you want to and you definitely need peace of mind about it.
RockAuto has the Beck/Arnley head gasket set for $137 and some change. I bought it at that price a few weeks ago, and I just checked again and it's still there.
Oh, and don't jump the gun man. Do every single diagnostic test you can to confirm it is the head gasket and not anything else. You really don't want to do this unless you have to. It's absolutely not fun, and it will take a lot longer than you will expect. And it's going to cost more than most would think as well - hoses, machine shop costs, etc. all add up SO fast.
