copeboyq45 wrote:....... I let it run for about 30 minutes because it was sittin up for about a year but its still smokin not to bad and has a skip.....
Did the previous owner ever change out a fuel injector? When you restart in the morning does the white exhaust smoke increase for a minute before settling down? It sounds like a leaky lower injector o-ring or an injector failed in the open position. Any condensate in the exhaust should have been gone after 30 minutes.
Tie in to the fuel line past the filter with a pressure gauge and see if the fuel rail is holding pressure. Turn the key to the on position and listen for the fuel pump to run for a few seconds. Turn off the key and see if it holds that pressure, about 35+ psi. If it's bleeding off an oring is leaking.
The skip may be a dead injector or two and maybe plugged injectors after sitting for a year. Ohm test your injectors to see how many are still firing.
http://q45.org/ohminjectors.html
